× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Xr500 Readyshare not recognizing external hard drive
iielmesswavy
Apprentice
Netgear XR500
Issue- Readyshare not recognizing or not seeing external hard drive.
External Hard drive-
SPECS
*External Hard drive running on NTFS File system*
GENERAL
  • Capacity
    2 TB (changed it to 4TB Hard drive)
  • Interface
    USB 2.0
  • Weight
    2.25 lbs
  • Manufacturer
    Western Digital Corp.
POWER DEVICE
  • Type
    power adapter
  • Nominal Voltage
    AC 120/230 V
  • Frequency Required
    50/60 Hz
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
Netduma-Fraser
NetDuma Partner
Re: Netgear Xr500 Readyshare not recognizing external hard drive
Message 2 of 6
iielmesswavy
Apprentice
Technically, yes, it shows WD My Book Essential is supported.
Message 3 of 6
Netduma-Fraser
NetDuma Partner
I assume you have tried both the available USB ports on the router? Can it be seen by your PC? When you first connected it to the PC did it require drivers/software to be downloaded before you could see it properly?
Message 4 of 6
iielmesswavy
Apprentice
Yes, I have tried both USB ports. Furthermore, when connected to the pc it did not require any special program to be installed.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
I would recommend you make a ticket directly with Netgear regarding this: http://support.netgear.com/ as it isn't the part of the software that we created, it isn't my strong suit. I don't think it will work if it isn't being detected and may be worth changes from NTFS to FAT32 for example or trying another drive.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1138 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
