- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Netgear nighthawk pro gaming xr500 problems with Fortnite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear nighthawk pro gaming xr500 problems with Fortnite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear CM1000 docsis 3.1 modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which setting should I put it on for the IPv6 of the XR500? The options are auto detect, auto config, 6to4 Tunnel, 6rd, Pass Through, Fixed, DHCP, and PPPoE.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did auto detect and then proceeded to run a ping plotter test. The results were the same as before, maybe even worse. There was however some settings within the auto detect that I had no idea what to do with. I will link a picture. Each different mode that I described in the previous post had its own unique settings like it does for the auto detect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
2606:4700:4700::1111
2606:4700:4700::1001
Then apply. Also in Internet Setup change the DNS to 1.1.1.1 and 1.0.0.1 and apply. Then redo your tests, one with IPv6 enabled and one without it please using the same 45% you had before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First one is with IPv6 and the second is without.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just did it at 10:30pm and it was just as bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have yet to check the ping through the geo filter. The ping when I play Fortnite is actually decent when it is working. Like 40-50. However, every 5 minutes or so, my net debug stats will show a large red X beside the ping number. At that point I'm pretty much unable to do anything. I teleport, rubberband, freeze, etc. when the red X comes up. After a minute or two the red X will go away and I'll be able to play for little bit, just for it to come back 5 minutes later. When the red X comes up, the ping number itself doesn't change that much, however there will be a lot of red lines on the graph beside the ping number. Pretty sure this graph displays my connection quality.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
