- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear password reset & still won’t login!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a problem with Netgear login?
I reset my password and naturally can’t use the previous password, but even after creating a new one I still can’t get in!
Help please!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear password reset & still won’t login!
Login to what? Your router's graphical user interface (GUI)?
That is a local address for the GUI on your XR500. It goes nowhere near the Internet. (You should even be able to get in without being plugged into the Internet.)
I'm afraid "can’t get in" could mean many things.
What are you doing and where does it go wrong.
By the way, it may not matter, but you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get better and quicker replies, and find other answers, over in the appropriate section:
Nighthawk Pro Gaming Routers - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I’m connected to my home network, I launch the Nighthawk app I then want to enable Remote Access which then pushes me to the Netgear Account Login page but regardless of password reset it still errors out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is mynetgear.
Have you set up an account there?
It does not use the same password as your router's GUI.
@GLO wrote:
....it still errors out.
What does "errors out" mean? Times out? Rejects password? Something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Locally I can log into the app, and when I go to enable the ‘remote login’ it bumps me to a Netgear Account Login page which is where this goes astray!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@GLO wrote:
Hi,
Again, it is kind of hards to understand what is going on here.
Goes astray?
Remote login works via mynetgear.com.
You need to set that up first.
When you try to enable Remote login on a router, it will; ask you for the details you use for mynetgear.com.
The username and password for mynetgear.com have nothing to do with the details you use to login to your router's browser graphical user interface, your wifi or this forum.
If you don't have those details, it will invited you to create an account. This is best done with the GUI rather than an app.
Maybe you have done all this. You don't say so and haven't answered questions that would have helped pin down what is going on.
