× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear xr500 ipv4 seemingly stops working randomly
Forzurda
Heyo, I bought my XR500 a good while ago, but the last few months I've had a really annoying issue where the IPv4 portion of the network, seemingly just dies, and doesn't come back until I reboot the router.
Doing a ping test to 1.1.1.1 and 8.8.8.8 (My preferred DNS servers) show both working just fine.
IPv6 is totally untouched and works perfectly.
And when I do a tracert to check where it dies, its always seemingly outside my network.
Last thing log said before I presume everything went wrong was "DHCP lease change." only other time I found it in the logs was just 1 minute before the last one.
NetGear Nighthawk XR500 connected to Altibox (Norway) Fiber
Using DumaOS v3.0.202
Message 1 of 10
Netduma-Fraser
NetDuma Partner
Re: Netgear xr500 ipv4 seemingly stops working randomly
Could you clarify what you mean exactly? Are you saying the internet completely cuts out? I did the same tracert as you and I had the same results as you where it times out after the ae124 domain - I only have IPv4 and connection is working fine. You cannot always ping/trace a specific IP if they block pinging for example.
Message 2 of 10
Forzurda
Basically when it happens, I can't use anything that is IPv4 only, for example sites like Reddit and Google, which have IPv6 addresses, I can access. But basically everything else like discord and duckduckgo, are inaccessible.
I confirmed this by checking test-ipv6.com, where it would show IPv6 address but no IPv4 address on all my devices, and doing a ping to google DNS would work but not much else.
It could be my ISP, but why I don't think so is because the issue gets resolved when I reboot the router.
Message 3 of 10
Netduma-Fraser
NetDuma Partner
Okay that's interesting, could you reproduce the issue then provide the logs from the System Information page please?
Message 4 of 10
Forzurda
I'm not sure how to reproduce the issue to be honest, from what I know it just happens randomly.
I can provide my full log or wait for it happen again?
Message 5 of 10
Netduma-Fraser
NetDuma Partner
Okay no worries, if you could wait for it to happen again then grab the logs and let us know the time it happened roughly so we can match that with the logs that would be really helpful
Message 6 of 10
Forzurda
It took a while but it has happened again, this time it showed the internet LED as orange, I re plugged the ethernet cable which provides internet but no luck. Only a reboot fixed it.
Log is under, LAN access remote is most likely my friends connecting to my minecraft server. As soon as I login is when it has died.
[admin login] from source 192.168.1.186, Wednesday, June 08, 2022 15:39:19
[admin login] from source 192.168.1.186, Wednesday, June 08, 2022 15:39:14
[DumaOS] Marking device that is marked 192.168.1.5 97 90., Wednesday, June 08, 2022 15:39:07
[DumaOS] DHCP lease change., Wednesday, June 08, 2022 15:39:06
[DumaOS] DHCP new event., Wednesday, June 08, 2022 15:39:06
[DHCP IP: 192.168.1.5] to MAC address 80:30:49:50:31:6d, Wednesday, June 08, 2022 15:39:06
[admin login] from source 192.168.1.186, Wednesday, June 08, 2022 15:39:01
[admin login] from source 192.168.1.186, Wednesday, June 08, 2022 15:39:00
[DumaOS] Marking device that is marked 192.168.1.5 97 90., Wednesday, June 08, 2022 15:38:38
[DumaOS] DHCP lease change., Wednesday, June 08, 2022 15:38:37
[DumaOS] DHCP new event., Wednesday, June 08, 2022 15:38:37
[DHCP IP: 192.168.1.5] to MAC address 80:30:49:50:31:6d, Wednesday, June 08, 2022 15:38:37
[DumaOS] Marking device that is marked 192.168.1.5 97 90., Wednesday, June 08, 2022 15:38:22
[DumaOS] DHCP lease change., Wednesday, June 08, 2022 15:38:22
[DumaOS] DHCP new event., Wednesday, June 08, 2022 15:38:22
[DHCP IP: 192.168.1.5] to MAC address 80:30:49:50:31:6d, Wednesday, June 08, 2022 15:38:22
[LAN access from remote] from 51.120.121.53:45984 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:37:06
[LAN access from remote] from 51.120.121.53:45974 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:56
[LAN access from remote] from 51.120.121.53:45964 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:46
[LAN access from remote] from 51.120.121.53:45954 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:36
[LAN access from remote] from 51.120.121.53:45942 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:26
[LAN access from remote] from 51.120.121.53:45932 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:16
[LAN access from remote] from 51.120.121.53:45922 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:36:06
[LAN access from remote] from 51.120.121.53:45912 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:35:56
[LAN access from remote] from 51.120.121.53:45900 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:35:46
[LAN access from remote] from 51.120.121.53:45890 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:35:36
[LAN access from remote] from 51.120.121.53:45878 to 192.168.1.10:25565, Wednesday, June 08, 2022 15:35:26
Message 7 of 10
Netduma-Liam
NetDuma Partner
That sounds like it may be a different issue I'm afraid, as you had to reboot the XR, the logs were cleared. Is that the full log file that you could see or was there any more?
Has it done this before, where it's lost connection and the WAN LED goes orange? Or is this the first time?
Message 8 of 10
Forzurda
The log file was way bigger but I could not send it due to the 20k character limit.
This is the first time it has simply refused the connection until a reboot, first time it has shown WAN as disconnected as well. The other times it has been refusing to connect me to any IPv4 site as shown in the above messages.
Message 9 of 10
Netduma-Liam
NetDuma Partner
In case it occurs again, can you please go to Settings -> Setup -> LAN Setup.
Then, set the minimum DHCP value 192.168.1.100.
Then, reserve IP addresses for each device on the network. Give them an IP address between 192.168.1.2 and 192.168.1.99.
Then, see if the issue occurs again.
Message 10 of 10
Discussion stats
  • 9 replies
  • 1048 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
