- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Network Monitor Not accurate
- Mark as New
- Bookmark
- Subscribe
- Permalink
Network Monitor is not showing how much internet each device is using accurately. I would do a speed test or watch a 4k video on my pc and it says my pc is using 0.002 download which has to be wrong. However, when I stream at a 4500 bitrate it shows correctly that im using 4.5 mbps upload. Im on the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Monitor Not accurate
This is definately a bug. Could I ask what kind of internet connection settings you're using? PPPoE? Static? This might have some bearing on wether the bug occurs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
where it says internet IP address it says get dynamically from ISP. as for your question i would have two tabs opened up and side by side. one for watching the video in 4k and one for routerlogin.com to see my network monitor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the connection does require a login. i have my xr500 connected to my modem from my isp by ethernet and all devices like my pc are connected to the xr500. my pc is connected by ethernet also, but other devices are connected by wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do i check if it is in modem mode currently?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
is this the only way for it to maybe work. will there be a firmware update perhaps? i dont feel like doing this.thanks though
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
did u guys do an update the dumaos looks different and i like the new look. its also updating my network monitor just fine. i would watch a 6000 bitrate stream and it shows that im using 6 download. and when i stop watching the stream the number changes. so i think its fixed bro.
- Mark as New
- Bookmark
- Subscribe
- Permalink
*correction* it still isnt perfect but it seems improved. the monitor doesnt accurately show e.g. when im watching a utube video in 4k the download is really low like <0.2 mbps or something. but when im downloading like a update for cod on ps4 it shows a really high number like >100 mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the network monitor has been fixed 100% im not sure if this is something you guys did on your end. if not , then it might've had something to do with my internet connection because i unplugged my isp modem and checked after and it works. my isp says my neighbourhood has a internet wiring problem where my internet goes in/out or my speeds get really slow. im not sure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
so i was looking back at this and you said my setup is PPPoE because i told you my internet connection requires a login. id like to correct that information as it was it was false my internet connection does not require a login. so would that might change anything in terms of what the problem might be. my network monitor is still having the same issues unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i bridged the modem and the xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
could it be my settings? on the dumaOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i've definitely played with the settings. im not sure what setting i changed that may have caused this.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
