× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
New Firmware for XR500: 2.3.2.32 (fixes disconnection issue)
Netduma_Jack
NetDuma Partner
You can download here: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
New features and enhancements:
  • Improved the Smart Connect feature
  • Supports USB printers.
  • Supports WiFi HT160 for Korea and Japan.
Bug Fixes:
  1. Fixes security issues.
  2. Fixes the disconnection issue for wired devices.
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 5
Swc37
Re: New Firmware for XR500: 2.3.2.32 (fixes disconnection issue)
So the firmware is older than the updated on and I am still having issues.  I did not install the older firmware though since it was older.  Any other suggestions why I keep getting kicked off and  have to reboot my router every day?
Message 2 of 5
Guru
Did you install this version manually and continue to use the router or was a factory reset performed after installing this version and setup from scratch?
Message 3 of 5
Guru
Is this the same version of last year? 9/7/2018?
Bug Fixes:
Message 4 of 5
Netduma_Jack
NetDuma Partner
Could you try manually installing this older firmware - it will then identify whether the cause of your disconnects is just in the latest firmware (so a software problem), or if it's in both (so more likely to be a hardware problem). Thanks.
Message 5 of 5
Discussion stats
  • 4 replies
  • 4397 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
