× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
New patch, no broadcast
jdklein
Tutor
Applied the latest patch and now getting no SSID broadcast. Multiple reboots. Pushed wifi on off button, has no effect. Anyone else with this problem?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: New patch, no broadcast
Check within Settings > Advanced > Advanced WiFi Settings that the radios are turned on, if they are then disable it, apply, then reboot the router. Then enable them, apply and reboot the router, does it come back then?
Also check SSID broadcast in the normal WiFi settings to ensure that's enabled for 2.4/5GHz.
Message 2 of 2
Discussion stats
  • 1 reply
  • 578 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
