Reply
Night Hawk XR500 eithernet not working
Mike4123
Follower
Recently picked up a Night Hawk XR500 and none of the eithernet ports are working, No light indcations that a eithernet cable is plugged in. I have the lattest firmware and haven't changed any of the settings.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Guru
Re: Night Hawk XR500 eithernet not working
Return the unit for another one.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 3
Netduma-Fraser
NetDuma Partner
So you can only configure the router via WiFi? Try a factory reset by holding down the reset button at the back of the router for 30 seconds and then give it a few minutes but if it doesn't work then definitely sounds like a hardware issue so would agree with Furry.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 488 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
