Orbi WiFi 7 RBE973
Reply
Night hawk x500 connection to NBN
Tybn
Tutor
Hello. I have recently moved into a new property and have had satellite NBN installed. The tech was on site today and indicated that the NBN is installed and receiving data.
I connected my X500 to the NBN box and ran the setup wizard and can not connect to the internet.
I spoke to the ISP and went through their trouble shooting and still nothing.
Having read some of the forums here, it appears that I need to set a few parameters manually on the x500 but can not quite follow them.
Can you please advise what I need to do to get the X500 to talk to the NBN box ?
Message 1 of 9
Accepted Solutions
Tybn
Tutor
Re: Night hawk x500 connection to NBN
Problem solved.
I changed the bridge control Settings in the router and it has worked a treat.
All up and running now.
Message 9 of 9
All Replies
Netduma-Fraser
NetDuma Partner
Do you know if you require anything such as PPPoE, VLAN, DHCP identifiers etc for a connection? If not you may need to ask the ISP about this. Are you connecting direct to the NBN Box or do you have a modem/router provided by them as well?
Message 2 of 9
Tybn
Tutor
Hi there. I’m just connecting straight to the NBN box
The guy at Harvey Norman said that the X500 could just plug straight in.
My ISP provides a username and password which I have entered.
I did a reboot of everything again and tried to re run the setup wizard on the router but it says that I have no internet connection
Message 3 of 9
Netduma-Fraser
NetDuma Partner
Go through the setup wizard, skip everything if needed as you won't get a connection until you finish that anyway. Then in Settings > Internet Setup choose no login, then apply, see if you get a connection. If not, select login and enter the details you were given, apply, see if you get a connection.
Message 4 of 9
Tybn
Tutor
Done both. Neither provides a connection.
Message 5 of 9
Netduma-Fraser
NetDuma Partner
Do you have another router you could put between the box and the XR to see if you get a connection that way? What is your ISP?
Message 6 of 9
Tybn
Tutor
I don’t have a spare router busy I suspect I could buy one.
I’m with iinet
Message 7 of 9
Netduma-Fraser
NetDuma Partner
For some PPPoE connections they also require a service name otherwise they won't connect, could you contact the ISP and ask them what specific details are needed to gain a connection please?
Message 8 of 9
Tybn
Tutor
Problem solved.
Message 9 of 9
Discussion stats
  • 8 replies
  • 1963 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
