× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
NightHawk XR300 random reboots
atomicdroid
Follower
Greetings,
I have an XR300 and within the last 2 months it has started randomly rebooting.
Here are the trouble shooting steps I have performed.
1.  Plugged the XR300 power cable into a different outlet.
2.  Logged into the XR300 as admin and let it check and apply a new firmware version.  Unit is now running the current version of
     the firmware.  Unit rebooted after it applied the new firmware version.
Neither of these two steps solved the problem.  Unit still randomly reboots.  In addition there does not
appear to be any entries in the LOG to indicate problems.
Would appreciate ideas on how to correct this problem.
Thanks,
Darryl
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Liam
NetDuma Partner
Re: NightHawk XR300 random reboots
Hey Darryl, thanks for creating a new topic. Could you please confirm if you factory reset the XR since installing the latest firmware? I'd suggest doing so as it clears out a lot of low level code from previous firmware that could cause issues.
Give that a go and let me know how you get on!
Message 2 of 2
Discussion stats
  • 1 reply
  • 936 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
