- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk XR700 GAMING ROUTER R-Apps not loading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's now 2022 I'm still having same problem that is "This R-App is not loaded yet, please try again in a minute." None of the R-Apps ever load Geo - filter, Qos, Device Manger, Network Monitor, Hybrid VPN. I've also done the whole changing the retry amount from 3 to 5, still doesn't work. Does anyone know what causes this problem?
My Current Version: V1.0.1.48 and when I check for updates the router says I can update to New Version: V1.0.1.48
Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk XR700 GAMING ROUTER R-Apps not loading.
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR700-DumaOS-3-0-Beta-Firmware/m-p/...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have good solution and excellent feedback for R-Apps not loading? Because 'trying beta 3.0' with factory reset is the last thing i would like to 'try'. Unless you are sure that issue is solved. Or is Beta enough tested after two years having this issue.
It's pain full.
- Mark as New
- Bookmark
- Subscribe
- Permalink
