× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NightHawk Xr 500 pro gaming
Hi guys and gals,
I’m pulling my hair out here.Ive spent a fortune on this router but can’t get it working at all.Im probably not as clued up as you guys so be kind I really need help.
I’m vdsl fibre from the cabinet so don’t have a modem on the wall so I needed a modem or a modem router in bridge mode.I read in one of the forums that the bt openreach modem would work.Bought one but for the love of me can’t get the internet light to turn from orange to white.please some one help.
Message 1 of 64
Netduma_Jack
NetDuma Partner
Re: NightHawk Xr 500 pro gaming
Does your modem need PPoE? Which means, do you need to enter credentials like a username and password?
If so, make sure you do this on the router?
If you connect directly to your BT hub, do you get Internet?
Message 2 of 64
Thanks for reply I’m not on by fibre I live in Hull we have a seperate telephone exchange who also supply our fibre lightstream.Im currently using a Technicolor modem router.im pretty sure you do need to sign in but the modem which is a bit openreach modem I was told in a netgear forum would work for vdsl from the cabinet which I am.Ive no settings for this it’s just plug and play lol.Need help setting it up on XR500 as I don’t know what I’m doing.
Message 3 of 64
Killhippie
Prodigy
What model router is it? Has it a setting called bridge mode?
Model: XR500| Nighthawk Pro Gaming Router
Message 4 of 64
Hi
No it’s just a basic modem no bells or whistles.I thought bridge mode was only for modem routers??Its a bt openreach modem
Message 5 of 64
Killhippie
Prodigy
Ok sorry your post didnt show you had bought a BT modem earlier for some reason... You should attach that to the wall if possible to keep it cool if its a HG612 as they run warm, but apart from that you plug it into the socket from your wall for FTTC into the port called DSL then from the modem port Lan 1 into the WAN (yellow) port on the back of the XR500. You then enter your username and password for your ISP in the settings when promted by the XR500 when you set it up
Message 6 of 64
Hi
I had done that already,username and password for what?to get into router settings or log into internet.My gripe is this,the internet light is flashing orange so can’t do the set up wizard thing at the start because when it spins at the start it comes up with “can’t detect internet”.i need someone to run me through step by step instructions cause at the mo I have an expensive ugly ass router sat on my living room floor collecting dust 😢😢
Message 7 of 64
Killhippie
Prodigy
The BT modem should pick up VDSL so does it show two green lights? Is it plugged into where the old router was plugged in? Does that have a dangly filter or a filtered faceplate? The username and password are what you use to log into your ISP. The XR500 will have an orange light untill you set it up with your ISP's username and password. Have you already logged into the XR500 before then and skipped the setup process?
Message 8 of 64
Killhippie
Prodigy
Can you confirm your service is not pure fibre, I thought Lightstream was pure fibre only? In which case you would have to use the router you have but change settings, are you sure you have FTTC (Fibre from the cabinet)
Message 9 of 64
Yes I’ve already done that once but then was really list with what to do if I’m honest and no real guides to follow.So I’m almost positive this by openreach modem will work,I have 3 green lights but only guide on YouTube to follow was the netgear video and that was if the internet light was green so need help doing it manually so to speak
Message 10 of 64
Killhippie
Prodigy
The modem has three green lights? Okay thats odd do you know if you use a username and password to use your internet? The XR500 launches a setup process when fired up for the first time have you done that?
Message 11 of 64
100% vdsl fibre from the cabinet which this modem supports
Message 12 of 64
Killhippie
Prodigy
right lets do thsi one step at a time. Is the BT modem showing three green lights or two? Have you tried starting the setup process on the XR500? When you plug the modem into the XR500 it launcehes a setup page has that happened or did you play with the XR500 first and not do that? I'm just trying to find out where you are 🙂
Message 13 of 64
Yes I have stated I have done this and get all white lights except internet which is orange
Message 14 of 64
Killhippie
Prodigy
So you have copper from the cab? Thats VDSL or if its fibre all the way its FTTP and a standard BT modem would not do that. What does the BT modem say on the back, can you give me what its called ie is it a HG612 or a ECI or is it something else?
Message 15 of 64
The modem shows two green lights until you plug into XR500 then it shows three.i have fiddled with XR500 before.can we reset amxr500 and start from scratch and you go through it and I will go downstairs and we can crack this.
Message 16 of 64
Killhippie
Prodigy
So now you open your browser and the XR500 launches a setup routinne have you done that? It will launch that setup with an orange light.
Message 17 of 64
Killhippie
Prodigy
reset the XR500 there is a reset hole in the back press that for 10 seconds with something like a bent paper clip. wait for a few minutes while it resets. Then launch your browser. Now do you know your internet username and password?
Message 18 of 64
Vdsl from the cabinet and it’s a echolife hg612
Message 19 of 64
Right let’s do this I need to unplug my other router etc get it all plugged in two mins
Message 20 of 64
Killhippie
Prodigy
okay  can you give me the details of your old router please I want to check something? Also have you taken your username and password from it?
Message 21 of 64
I’m sure I have my user name and password.my old modem router is a Technicolor TG589vac v2
Message 22 of 64
Killhippie
Prodigy
Thanks, you will need your username and password to set up the XR500.
Message 23 of 64
Right I’m reset and on the router dashboard,modem is plugged in and three green lights Ethernet connected to lan1 on modem into yellow Ethernet port on xr500.im at netgear service agrrement
Message 24 of 64
Killhippie
Prodigy
Just so you know your old technicolour could have been used in bridge mode, if you ever need to set it up as a pure modem here is a link. https://www.youtube.com/watch?v=Kahed6fbXTg
Message 25 of 64
Discussion stats
  • 63 replies
  • 5041 views
  • 5 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
