×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
NightHawk Xr 500 pro gaming
Hernandezh185
I have a problem trying to connect to my Nighthawk XR500. I have AT&T as an internet provider. Please help!!!
Message 1 of 6
Netduma_Alex
NetDuma Partner
Re: NightHawk Xr 500 pro gaming
So you've got an AT&T provided modem I assume? You have connected that with an ethernet cable to the WAN port on the XR500, and then gone through the setup procedure, but can't get an internet connection?
Do you need a PPPoE login for your network? Did your previous router have any settings that you needed to change to get it to work?
Message 2 of 6
Hernandezh185
Yes I have a problem trying to connect my devices to the router such as my ps4 it keeps giving me an error code
Message 3 of 6
Netduma-Fraser
NetDuma Partner
What error code are you getting? Are any devices successfully connected to the router? Is it just the internet you can't access or the interface as well?
Message 4 of 6
Hernandezh185
I am not able to connect to any of my devices
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Are you trying to connect via ethernet or WiFi? Are you able to connect a device via ethernet to access the interface?
Message 6 of 6
Discussion stats
  • 5 replies
  • 1003 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
