Reply
Nighthaw x6 R8000 offline setup?
Rambo111003
Hi there! my ips recently blocked me from using my wifi without inputting there settings and i recently factory reset my wifi so i need to visit routerlogin.net. but my router cant connect because it wont work without internet. is there any way to bypass this step in the setup? thanks for your help Smiley Happy
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Guru
Re: Nighthaw x6 R8000 offline setup?
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Discussion stats
  • 1 reply
  • 584 views
  • 0 kudos
  • 2 in conversation
Announcements
