- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Pro Gaming XR450 connectivity issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having issues with my Nighthawk Pro Gaming XR450 that I purchased from Costco about two years ago.
On my network, I cannot connect to sites like Disney+, Hulu, Amazon Prime, or certain game servers. With my Oculus Quest 2, I cannot connect to most multiplayer games. I'm not sure why this is, because on other people's networks, I can. I haven't changed many settings from within the router DUMAOS other than changing passwords, changing my DNS to 1.1.1.1 and 1.0.0.1. that's really about it. And I was having the same issues before I changed any DNS settings. I'm getting the right speeds that I should be getting with my ISP, but many sites just wont load.
I would like to solve this issue without factory resetting the router as I have quite a few smart home devices that are connected, and I would hate to have to go through and reconnect everything. If at all possible.
Thanks in advance for any advice given.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Pro Gaming XR450 connectivity issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
what modem gateway is it connected to?
Did it ever work properly? and if so, when did it change and what was changed when it stopped?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I disabled it as suggested and it seemed to have solved a lot of the issues. Still not getting certain things to stream online though. Firmware is also updated to latest.
thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It did work properly when I first set it up. Not sure when/how it stopped working. Can't recall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem/gateway its connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have a traditional modem. There's an ethernet plug in the wall that I connect directly to. And it goes to a box outside my house. fiber.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What ont is it and who's your provider?
Each have their own specific settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suppose I'd have to try connecting the apple tv directly to the ONT. I will try tomorrow and report back. The issues came back and even with QoS disabled. I also reset the router. Although, I may have done that wrong as all of my devices connected again after it reboot. I held down the reset button for 25 seconds...
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
