Reply
Nighthawk Pro XR500 Registration Issues
Reinie
Initiate
Hello,
I am trying to register my XR500 for warranty, however when I click submit on the product registration site I get no confirmation;
It is as if the site simply refreshes, and I get no e-mails or any sign showing that it worked.
Is there anything I can do, or is this a server-sided issue?
Thank you
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 4
Guru
Re: Nighthawk Pro XR500 Registration Issues
@Christian_R
@Blanca_O
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 4
Netduma-Fraser
NetDuma Partner
Recommend creating a ticket and seeing if they can confirm if it went through or complete it for you
Message 3 of 4
Christian_R
NETGEAR Employee Retired
Hello @Reinie
Please send me a message with your name, email your registered the device to, and the serial number of your XR500.
~Christian
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1001 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
