Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4S AC2600 R7800 Ping Spikes
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-03-21
09:16 AM
2019-03-21
09:16 AM
im on ethernet. im sure its not isp problem cause i pinged my router
most of the ms is <1
but sometimes its higher than 2000
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-03-21
09:33 AM
2019-03-21
09:33 AM
Re: Nighthawk X4S AC2600 R7800 Ping Spikes
http://prntscr.com/n12ly3 thats a good picture for refrence. tried to return the firmware like i saw in another post here. didnt work.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-03-21
11:10 AM
2019-03-21
11:10 AM
Hi Rifle, I would suggest you post here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk as this part of the community forum is for the Nighthawk Pro Gaming routers (XR450, XR500 & XR700).
Just to add my two cents so you have something to go on before posting in the new forum. If you're pinging the router itself and getting a spike then its likely either the ethernet cable you're connecting to it with or the WiFi experienced congestion. In general pinging the router is not a good way of determining the quality of your connection. You'll want to ping something like Twitter or Google instead.
Message 3 of 3
Announcements
