× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Nighthawk XR1000 Router - Reboots every few hours
I have had this router for about 2 months and the performance is great when it works - however it reboots every few hours.   This is destroying my ability to work from home and to enjoy gaming.   When it reboots/crashes I observe the red light on the center of the router is lit - I lose all wired and wireless devices when this happens.   I am using this router connected to an Xfinity Modem - the Xfinity modem is in bridge mode so all DHCP and functions such as this are taking place in this XR1000.   Guest wireless is not enabled.  I am not using a VPN.
I have one port forward setup to access my security DVR cameras - rule is working and persists after these unwanted reboots.
I have updated the firmware to 1.0.0.58_1.0.44 and it is running DumaOS 3.0.216.     Any help is appreciated with this - I really want to like this device but I am extremely disappointed with it's behavior.
System Info
System InfoUptimeRouter TimeTime ZoneBoard ModelFirmware VersionDumaOS Version
12 minutes 58 seconds
Sun Apr 10 15:48:30 2022
(GMT-5:00) Bogota, Lima, Quito
XR1000
1.0.0.58_1.0.44
3.0.216
Also - the log files seem to only exist from startup until reboot.   Is there a place I can access historical logs and see what event is triggering these reboots?
The earliest thing in my logs is this
[DHCP IP: (192.168.1.10)] to MAC address , Sunday, Apr 10,2022 15:37:43
[LAN access from remote] from ^^^^ port 443 to 192.168.1.19 port 40258 Sunday, Apr 10,2022 15:37:42
[DHCP IP: (192.168.1.11)] to MAC address , Sunday, Apr 10,2022 15:37:41
[DHCP IP: (192.168.1.9)] to MAC address , Sunday, Apr 10,2022 15:37:38
[DHCP IP: (192.168.1.8)] to MAC address , Sunday, Apr 10,2022 15:37:35
[LAN access from remote] from **** port 443 to 192.168.1.19 port 41085 Sunday, Apr 10,2022 15:37:34
[LAN access from remote] from **** port 443 to 192.168.1.19 port 44476 Sunday, Apr 10,2022 15:37:34
[Time synchronized with NTP server] Sunday, Apr 10,2022 15:37:32
[Internet connected] IP address: 66.30.121.196, Sunday, Apr 10,2022 15:37:32
[DHCP IP: (192.168.1.2)] to MAC address , Sunday, Apr 10,2022 15:37:28
[DHCP IP: (192.168.1.7)] to MAC address , Sunday, Apr 10,2022 15:37:25
[DHCP IP: (192.168.1.6)] to MAC address , Sunday, Apr 10,2022 15:37:24
[Internet disconnected] Sunday, Apr 10,2022 15:37:20
[DHCP IP: (192.168.1.5)] to MAC address , Sunday, Apr 10,2022 15:37:20
[DHCP IP: (192.168.1.3)] to MAC address , Sunday, Apr 10,2022 15:37:18
[Initialized, firmware version: V1.0.0.58_1.0.44] Sunday, Apr 10,2022 15:37:18
Show Statistics
System Up Time 00:23:09
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WAN1000M/Full615802858800759828902300:21:18
LAN1100M/Full94751250309671315400:21:23
LAN21000M/Full2814819720015585311400:21:23
LAN3--0000000:23:09
LAN4--0000000:23:09
2.4G WLAN b/g/n/ax600M257303443490245152510200:23:09
5G WLAN a/n/ac/ax2400M3677131500025603462600:23:09
Message 1 of 9
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Nighthawk XR1000 Router - Reboots every few hours
There is a more up to date firmware so I would recommend installing that and then doing a factory reset for a fresh setup and see if it makes a difference. Otherwise, is the router connected to an power extender or direct to a wall outlet? We've seen issues like this resolved when it's connected direct to an outlet.
Message 2 of 9
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 9
It is plugged into a power strip - I will try moving it to a direct wall outlet.
What firmware is available that is more up to date?  I did update it it and reset when I first received it but it now claims it is up to date.  I'll do a look around for a newer version manually.
Edit - I found XR1000-V1.0.0.64_1.0.49 on this site - will be updating and will report result.
Thanks
Message 3 of 9
Guru
What CAT# LAN cable is connected between the router and ISP Modem/ONT?
Message 4 of 9
I updated the firmware and it was hopeful but it then rebooted on me.   I then took the extra step advised and connected the power directly to the wall outlet and got the power strip out of the equation - and now I have 2 days+ of uptime.
Thanks!
SKIP PANEL
System Info
System Info
2 days 1 hour 34 minutes 51 seconds
Tue Apr 12 21:20:20 2022
(GMT-5:00) Eastern Time (US & Canada)
XR1000
1.0.0.64_1.0.49
3.1.1
Message 5 of 9
My XFinity Modem info is below:
Model:CGM4331COM
Vendor:Technicolor
Hardware Revision:2.0
Serial Number:************************
Processor Speed:1503 MHz
DRAM Total Memory:1024 MB
DRAM Used Memory:680 MB
DRAM Available Memory:344 MB
Flash Total Memory:2048 MB
Flash Used Memory:134 MB
Flash Available Memory:1914 MB
eMTA & DOCSIS Software Version:Prod_20.2_d31 & Prod_20.2
Software Image Name:CGM4331COM_4.11p7s1_PROD_sey
Advanced Services:CGM4331COM
Packet Cable:2.0
Message 6 of 9
Netduma-Liam
NetDuma Partner
How're you getting on with the new firmware? Has it helped?
Message 7 of 9
@Netduma-Liam
After I update the firmware I was hopeful but it rebooted after about 2 hours.   I then moved it out of power strip and directly to wall and no issues since - uptime now over 4 days.
4 days 1 hour 41 minutes 51 seconds
Thu Apr 14 21:27:20 2022
XR1000
1.0.0.64_1.0.49
3.1.1
Message 8 of 9
Guru
Just curious, what is the brand and model # of the power strip you had been using?
Message 9 of 9
Discussion stats
  • 8 replies
  • 2751 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
