× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk XR300 2.4g and 5g merge
konradsroka
Follower
Is there any way to merge 2.4g and 5g on the Netgear Nighthawk XR300? I've seen someone be able to do this on a XR500 but i'm not sure if it's possible or not on this model. The firmware version is 1.0.3.38_10.3.30 if thats needed.
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: Nighthawk XR300 2.4g and 5g merge
Smart Connect (the feature that allows this on the other XR routers) isn't available on the XR300 unfortunately.
Message 2 of 2
Discussion stats
  • 1 reply
  • 594 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
