Discussion stats
  • 2 replies
  • 293 views
  • 1 kudo
  • 3 in conversation
Announcements
Reply
Highlighted
Follower
Nighthawk XR500 - keeps changing the PPPOE password
Hi,
am having a problem with this router. For a long time i have faced numerous internet disconnections, that i had to restart the router couple of times and wait for hours to suddenly work and it happens about every 2 days. After contacting my service provider he asked what brand my router was i said Netgear. he said that couple of people with same issue with netgear , he said some kind of bug that causes the router to randomly change or forget the PPPOE internet provider password. i didnt believe it at first , but when i got disconnected i tried to retype the password, and it immediatley went online and that fixed it every time !! now i dont want to loose the internet suddenly and retype it every two days any fix ?? i have latest software for the router. too bad for a very expensive router Smiley Sad
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Highlighted
NetDuma Partner
Re: Nighthawk XR500 - keeps changing the PPPOE password
This definitely shouldn't be happening. Have you tried installing this hotfix firmware for dropouts? It might help you out.
https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
Message 2 of 3
Highlighted
Guru
Be sure to factory reset the XR router after loading FW and setup from scratch.
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 3
