Orbi WiFi 7 RBE973
Reply
Nighthawk XR500 slow upload
Sand323
Guide
Hi guys, spectrum around my area just got upgraded to 1 gig and since the upgrade my router just went to crap. My download got better but my upload won’t exceed pass 2 can anyone help??
I’ve already factory reset my router twice and spectrum already came down twice and there connection is solid.
Message 1 of 10
Accepted Solutions
Guru
Re: Nighthawk XR500 slow upload
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 9 of 10
All Replies
Guru
Message 2 of 10
Netduma-Fraser
NetDuma Partner
Have you entered your new/expected speeds in Bandwidth Settings? Where are you testing the speeds exactly?
Message 3 of 10
Sand323
Guide
Yes, I put the new speeds into the bandwidth and have been testing the speeds through the router log in for the dumaOS
Message 4 of 10
Netduma-Fraser
NetDuma Partner
Test on speedtest.net, what speeds do you get?
Message 5 of 10
Sand323
Guide
I get 340 down and 2 up
Message 6 of 10
Netduma-Fraser
NetDuma Partner
Could you attach a picture of your QoS page please?
Message 7 of 10
Sand323
Guide
Spectrum maintenance crew has been out here for a couple hours already and ended up fixing whatever was wrong.
My XR500 is back to running at optimum levels.
Thanks for the help, really appreciate it.
Message 8 of 10
Guru
Enjoy. 📡
Message 9 of 10
Sand323
Guide
Thanks for the tip
Much appreciated.
Message 10 of 10
Discussion stats
  • 9 replies
  • 3050 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
