Reply
Nighthawk XR500
Dlucas78
Nighthawk XR500
I have purchased and upgraded my home router to the AC2600.  I have also upgraded my 1GB internet.   However when I have my computer plugged directly into the router.  My speed never will go to above 300mps on the speed test.  I can plug my connection directly into the IP Modem, and get around 980 Mps.  I have contacted my ISP and they tell me that Nighthawk XR500 can't go about 300mps.  I have loooked through the forms I can't find anyone that has had this problem.   I wanted to post and see if anyone has seen this and if there is a setting on the Nighthawk Pro XR500, that I am missing to turn on so I can get the speed up to 1Gps.   Thanks for everyones help.
Thanks
David
Message 1 of 8
Guru
Re: Nighthawk XR500
What FW is currently loaded?
Do a reset on the XR router and walk thru the setup wizard. When it gets to the detected internet speed. Let us know what it detects here.
You can also manually input speed settings 1000/1000 I believe under QoS...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 8
Dlucas78
Re: Nighthawk XR500
Nighthawk current Firmware 2.3.2.32
ISP Modem Netgear CM-1000-1AZNAS
DOCSIS 3.1 21X8
Message 3 of 8
Dlucas78
Re: Nighthawk XR500
When it goes through the setup and dectects the speed I get 300/300  which it is suppose to be 1 GPS up and 1 GPS down.
Message 4 of 8
Guru
Re: Nighthawk XR500
What happens if you manully input 1000/1000?
Something you need to contact NG support about.
Message 5 of 8
Dlucas78
Re: Nighthawk XR500
I have spoke to netgear support for 3 times. They keep telling me to call my ISP. My ISP tells me to call netgear. When I change it to 1000/1000. My router slows network to a crawl
Message 6 of 8
Netduma_Jack
NetDuma Partner
Re: Nighthawk XR500
Hi Dlucas,
First of all the Nighthawk can definitely do over 1000mbps speed, so ignore your ISPs advice there!
Could you try this please:
  1. Disable QoS in Anti-Bufferbloat's options (click the three horizontal lines in the top left corner of the panel)
  2. Does your modem have a bridge mode or a modem mode option? If so, please enable that
  3. Disable IPv6 in >Settings >Advanced
One other thing - does your connection use PPPoE?
Message 7 of 8
Netduma_Jack
NetDuma Partner
Re: Nighthawk XR500
If disabling QoS gets you to full speeds, could you follow this guide to get QoS setup correctly to allow full speeds: http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-spee...
(you'll need to re-enable QoS first of all).
Message 8 of 8
Discussion stats
  • 7 replies
  • 931 views
  • 0 kudos
  • 3 in conversation
Announcements
