Reply
Nighthawk Xr 500
unceasingtech
Follower
Nighthawk Xr 500
Please i need help my geo filter is not enable to find any servers for fortnite as you have shown in the videos on youtube please help me i couldn't find any servers for fortnite.Is there anything to change in my windows settings or what else i could do.Please reply.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Guru
Re: Nighthawk Xr 500
Review this:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Ultimate-NAT-Guide-and-settings-for-XR...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
Netduma-Fraser
NetDuma Partner
The way that Fortnite works is that it attempts to load you into the server before it's been allowed or blocked. If its outside your radius it'll still try to load in so wait then re-search and game should be within your radius. Alternatively you can use Spectating Mode / Full radius to see where the server is located and if you don't like it, back out of the lobby and search again.
Message 3 of 3
Discussion stats
  • 2 replies
  • 485 views
  • 0 kudos
  • 3 in conversation
Announcements
