- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk has stopped Broadcasting Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Installed the XR500 and it initially worked flawlessly...for a couple of days. First the 5GHz Wifi network disappeared but the 2,4GHz stayed up. But now both have gone. It is also only the 2,4GHz white light on the XR500 that is lit (First three LED:s all white) and yes, the button lights ontop of the box also white. I have done a soft reset, a factory reset and restarted the modem.
The the OS on the router says everything is fine and broadcasting. But I cannot see the WiFi network on any of my devices. (Iphone, Laptop, TV etc)
IT works LAN connected though. AND I have the latest Firmware.
I cannot find anyone else with the same problem on Google or on this forum.
What should I do???
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk has stopped Broadcasting Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I even disabled it, did an "Apply" and then Enabled it again too see if it did anything. But nope.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry to say, that did not help either. (I restarted the router also.)
Noticed also that the white LED for the 2,4GHz is also flashing steadily like once every second. (5GHz LED still black).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly you have smart connect enabled and devices don't support this. If so disable, can you see them now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the support seems to be the way to go. 😕
Have run with both smart connect on and off, and I have played with channel settings as well but nothing. I am starting to suspect hardware issues.
Big thanks for the help though!
Cheers!
