- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk iOS app wont’ work with Orbi AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently added Orbi Access Points to my XR500 network and now when I try and use my nighthawk app. Keeps saying Router Not Supported - seems it must be trying the Orbi not my XR500.
Any idea how I can fix this. Thought there would have been an IP option on the app so i could select my router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk iOS app wont’ work with Orbi AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah i disabled the wifi - i tried reabling the WiFi and connecting directly to the router and yeah the app will work but the Orbi app than fails haha.
Surely there must be a way to get the app working as I can connect to the router using the IP while connected through the Orbi System
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would want to be connected to the XR500 when using the Nighthawk app and then connected to the orbi wifi when trying to use the orbi app. Since the orbi is in AP mode not much you would really be able to do on the orbi app since it is just handling wifi and the Xr500 is doing all the routing.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
But i would have to disable my Orbi and turn on my router wifi to get that to work... it should be possible to point the I.P of the router on the actual app since i can access the Router GUI from my phone while connected to the Orbi AP. seems a oversight when having 2 netgear products on the same network.
