Amarosh's avatar
Amarosh
Nighthawk pro gaming router xr700 2.4 and 5ghz not working
I’ve been trying to figure this out for two days now I’ve tried rebooting the router multiple time I’ve reset it, tried the WiFi button, tried the radio signals in the advanced wireless option on duma is downgrading it ect ect it was working fine then the WiFi just cut out and hasn’t worked since I put it in so mode and the 2.4ghz and 5ghz light came back on but I couldn’t connect to the WiFi and then they shut off again.
  • Disable the WiFi radios in Advanced WiFi Settings then reboot via the interface, wait 1-2 minutes then enable them both again, reboot then wait a few minutes, is it back?
