Reply
Nighthawk rx300
SychoOverkill
Follower
Nighthawk rx300
Hi. New to the gaming router when I first plugged everything I had fast speeds to my ps4 and now the speeds are and everything has dropped can barely get into games does anyone know the fix for that?
Message 1 of 3
Guru
Re: Nighthawk rx300
Is the game console wired or wireless connected to the XR router?
Do you get good speeds with a wire connected PC?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
Netduma-Fraser
NetDuma Partner
Re: Nighthawk rx300
What were the speeds on the PS4 and what are they now? Console speed tests can be inaccurate, if you do a speed test on a wired computer what results do you get? Gaming requires very little bandwidth so it is unlikely that is the cause of the issue - what game are you playing and are you using the Geo-Filter?
Message 3 of 3
Discussion stats
  • 2 replies
  • 892 views
  • 1 kudo
  • 3 in conversation
Announcements
