× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk x6 ac3200 power fail? Router won’t stay on
Alexpapa413
Follower
Please help, my router won’t stay on. When I turn it back on manually or power back up it flashes Amber in the power section, then all the other lights flash white fast and slowly start to dim out after about ten flashs.
Any info appreciate
Message 1 of 3
Guru
Re: Nighthawk x6 ac3200 power fail? Router won’t stay on
I take it you meant the R8000? ac3200 isn't a model number.
What firmware is on it?
How old is it?
Do you have any way of checking the power supply? (aka multimeter)
https://www.netgear.com/support/product/R8000
Message 2 of 3
Guru
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Any info appreciate
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1135 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
