Reply
Nighthawk
Imitable
Nighthawk
Anyone else having any problems trying to change the nat type from strict to open?
Message 1 of 10
Guru
Re: Nighthawk
What problem are you having?
What router are you using?
Firmware on that router?
What modem are you on?
Maybe explain exactly what you're trying to do and why you're trying to do so. This will let us to help you better.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 10
Imitable
Re: Nighthawk
The router I am using is the AC2400 and the modem is the AC1900
The problem that im having is that when I try to play any of the call of duty games my NAT type is set to strict instead of open.
Message 3 of 10
Guru
Re: Nighthawk
Neither of which are model numbers. But from the sound of it you're in a double nat. Is the router in ap mode or the modern in passthrough mode?
Message 4 of 10
Imitable
Re: Nighthawk
The router is in Ap mode.
Message 5 of 10
Guru
Re: Nighthawk
What specific devices are you using? AC2400 and AC1900 are speeds, not models.
Firmare on them?
What are you playing call of duty on?
PS4, Xbox, Pc?
And is it wireless/wired, how is it connected?
And then is it connected via the AP device (which is?) or the primary router?
Is it the only game with issues?
Message 6 of 10
Imitable
Re: Nighthawk
Model numbers for these are
Modem : C7000v2
Router : Ac2400
Playing on my Pc
Wired connection from my router the Nighthawk Ac2400 model
Its the only game where I can see the NAT type im assuming the other games are perhaps also encountering this issue.
As for the firmware for the modem its
V1.03.01
And for the router it is
V1.2.0.62_1.0.1
Message 7 of 10
Guru
Re: Nighthawk
Modem : C7000v2
Router : Ac2400----not the model. Based off your firmware, you're using R6700v2
Playing on my Pc
V1.03.01
V1.2.0.62_1.0.1
so the R6700v2 is in AP mode?
Is the pc directly connected to the R6700?
and thats hardwired to the C7000?
Is it causing an issue during gaming?
Message 8 of 10
Imitable
Re: Nighthawk
Yes the pc is connected directly to the R6700v2 and the R6700v2 is connected directly to the modem. It does cause lag issues when Im going and have noticed that games take longer to find.
Message 9 of 10
Guru
Re: Nighthawk
If the R6700 is in ap mode, there shouldn't be much to adjust on it. Theres a few settings on the C7000 that might help but a lot depends on what works best for that specific game, you could check that games forum for tips.
https://kb.netgear.com/23020/Opening-ports-for-internet-games-and-applications-on-NETGEAR-routers
Message 10 of 10
Discussion stats
  • 9 replies
  • 1051 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
