- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Access Control on XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
DUMAS OS has a block feature. Once a device gets in, you can block it, but it doesn't stop that device from getting back in. I have had the same device on my network, after blocking it 5 times. There were 5 icons of the same device which showed blocked while the device is still shows an active connection on a 6th connection. I am guessing that if a devices IP is changed, DUMAS thinks it's a new and different device, so simply unplugging and plugging in again a ethernet cable could do this. I did a factory reset, when it happens again, I will post a screenshot.
I have spoken to Customer Care but the XR1000 is too new for them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Access Control on XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just upgraded from the WNDR3700v4 to the XR1000 and the Access Control feature from the 3700 is sorely missed. I don't think I can overstate how much I would like to see this feature added (back) to the OS on the XR1000.
The only workaround I have found which mimics the Access Control feature is to define a Traffic Controller rule which rejects all devices with a higher priority rule that allows the specific devices I want. But this is not a sufficient way to accomplish Access Control as I can't easily see what is being blocked when a new device is connected to the WiFi or LAN. All I see is a message like:
Reject All | 12/7/2020, 5:34:06 PM | rejected a device for all traffic |
Having the ability to quickly see the devices that have been blocked (with their MAC address) and make the choice to allow those devices is a much desired feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If there's a setting for it, disable DHCP and manually assign an IP to every device currently connected and make the subnet mask or ip range, whatever it's called, is limited to the amount of devices you have (For example, for 3 devices, 192.168.1.1 for the router, 192.168.1.2-192.168.1.4 for the 3 devices) and now any new device (Ethernet or WiFi) can't get an IP unless you extend the range and assign it an IP (Idk hopefully that works). If DUMA OS is thinking the device is a new device, it could be MAC spoofing from the device (Usually a PC or laptop). Also watch out for sneaky iOS 14 people as they have a new WiFi feature called "Private address" whcich uses a random fake MAC address seperate from their real MAC address so technically they get 2 MAC addresses. They get only the same 2 (Real MAC address and fake MAC address) MAC addresses based on WiFi so you only have to block 2 MACs and they don't have unlimited MACs. Even if they forget and reconnect to your WiFi, their fake MAC address will still be the same so no worries there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yo that's actually a sick idea, but that's whitelist access control. Blacklist access control isn't as useful though as someone can just factory reset their iPhone network settings and get a new MAC address/use random MAC/hardware address on Android/Windows.
