× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
No high priority ddetected (no red light)
i got my new router yesterday and when i first set it up it was detecting high priority traffic and working as expected, today it shows no detection (no red light) and also shows no high priority packets being sent or revieced, ive port forwarded fortnite in the settings and still shows no high piority traffic detected. I'd appreciate any help 🙂
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 11
Netduma_Alex
NetDuma Partner
Re: No high priority ddetected (no red light)
As well as Port Forwarding Fortnite, have you put those ports into Traffic Prioritization? Also, is DumaOS Classified Games enabled in the Traffic Prioritization menu?
Message 2 of 11
prior to this post i hadnt added any ports to the traffic prioritization area but now i have, i also enabled dumaOS classified games, thanks for the help i'll let you know if it works 🙂
Message 3 of 11
so its been a week now and i havent noticed any changes, still no traffic priority detected, ive removed all port forwarding and returned to out of the box settings and it still wont detect anything, dumaos games is enabled and still nothing. multiple reboots havent changed anything either, id love any other help you can offer.
Message 4 of 11
Netduma-Fraser
NetDuma Partner
Have you disabled QoS in the Anti-Bufferbloat menu? If so that will be the reason why it isn't working.
Message 5 of 11
QoS is enabled and still doesnt detect anything. it worked when i first set it up but now it doesnt. this is the traffic priorotization section while fortnite is open. qos.JPG
Message 6 of 11
Netduma-Fraser
NetDuma Partner
Can't see the picture at the moment as it hasn't been moderated. Are you playing Fornite on PC or console? Have you tried using the console service to see if it works that way?
Message 7 of 11
playing on PC where would i find the console service to see if it has any affect?
Message 8 of 11
Netduma-Fraser
NetDuma Partner
Add a manual service to Traffic Prioritization and just click 'Console'.
Message 9 of 11
seems to have worked! i'll let you know if it keeps working, thanks for the help!
Message 10 of 11
Netduma-Fraser
NetDuma Partner
Great, keep us posted!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1700 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
