- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Not getting 1GB connection from x6 R8000 nighthawk router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently got 1gbps fiber coming into my house. For some reason, I cannot get above 300mbps out of the router. I don't have anything special setup. I've run tests from a computer connected to the fiber line and that all comes out ok. However, I can't seem to get the full speed from the router. I tried setting my speeds manually, but as soon as it applies it goes back to "let speedtest detect my speed." The advanced statistics show 1000MB/Full for the WAN. The 5g WLAN report 1300M/Full.
I do not have QOS running. I turned off network monitoring. I do have Bitdefender running, however shutting it off did nothing to help. Do I reset the factory settings on this thing, or go replace it with a newer one?
Thanks in advance for your help/suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Not getting 1GB connection from x6 R8000 nighthawk router
Qos, traffic monitoring, parental controls aren't recommended at speeds >250mbps.
And I've heard of their settings being retained even though disabled and rebooted.
I'd try a factory reset and then during install, only setup the things necessary to get it working. Then speedtest.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
