× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Not more than 30 devices able to connect
modjoul105
Hi,
I am trying to connect multiple (around 30) wearable smart-belts to the Nighthawk XR500 router but there is the loss of connection frequently. When I check the logs there seem to be a large number of  ARP attacks. Something like shown below
[DoS Attack: ARP Attack] from source: 10.0.0.12, Thursday, October 04, 2018 13:22:06
[DoS Attack: ARP Attack] from source: 10.0.0.12, Thursday, October 04, 2018 13:22:05
[DoS Attack: ARP Attack] from source: 10.0.0.15, Thursday, October 04, 2018 13:21:55
[DoS Attack: ARP Attack] from source: 10.0.0.15, Thursday, October 04, 2018 13:21:53
[DoS Attack: ARP Attack] from source: 10.0.0.6, Thursday, October 04, 2018 13:21:52
[DoS Attack: ARP Attack] from source: 10.0.0.15, Thursday, October 04, 2018 13:21:50
[DoS Attack: ARP Attack] from source: 10.0.0.6, Thursday, October 04, 2018 13:21:49
[DoS Attack: ARP Attack] from source: 10.0.0.15, Thursday, October 04, 2018 13:21:48
[DoS Attack: ARP Attack] from source: 10.0.0.15, Thursday, October 04, 2018 13:21:41
[DumaOS] DHCP lease change., Thursday, October 04, 2018 13:21:38
The smart-belt device uses an ATWINC1500-MR210PB wifi module with a SAMD21G microcontroller to send data at the rate of 3 KBps to the aws cloud via the MQTT server. What I am unable to understand is the reason for the router to treat the connection attempts from the belts as ARP attacks.
Also, the logs keep showing DHCP lease changes happening for the smart-belt devices that are connected. My understanding, based on calls with NETGEAR customer support, is that the lease time is 24 hours. Not sure why so many new events for the DHCP lease change are happening.
Any help would be highly appreciated.
Thanks
Itmenon
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 6
Guru
Re: Not more than 30 devices able to connect
Just curious are you using this router for gaming with game consoles and PCs or something else?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 6
Netduma-Fraser
NetDuma Partner
If you give them static IPs does that resolve the issue?
Message 3 of 6
modjoul105
Nope. It's just my laptop that I am connecting so I can monitor the logs, and then the 30 wearable devices. The total bandwidth consumption is less than 1 Mbps for all devices combined.
modjoul105
Message 4 of 6
modjoul105
Tried that. It didn't stop the ARP attacks from showing up when I connect the smart-belts.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Disable QoS completely from Anti-Bufferbloat settings and see if that resolves it please
Message 6 of 6
Discussion stats
  • 5 replies
  • 1430 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
