Reply
OG Xbox 128mb Upgrade
Olympiapeter
Follower
Hi guys. I am trying to do a 128mb upgrade on my OG Xbox and so far its not going well. I have soldered 5 different chips on the board to test, 3 recovered from old xboxs and 2 brand new ones and none seem to work.
I have checked for bridges on each one and also checked every leg is soldered and yet they still will not show up as working in Xblast OS.
I am starting to think the bios may be the issue? I installed the 256k ind-bios 5004 F+G from the Hexen 2019 disc.
Any help would be much appreciated because at this point I am about to give up Smiley Sad
Thanks.
Message 1 of 2
Guru
Re: OG Xbox 128mb Upgrade
This is a NetGear Gamer router forum.
Thanks.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 453 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
