× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
PING HeatMap Will Not Load
longr5310
Hello,
    Even after sync up the cloud three times on Geo filter, the Ping Heatmap will not load. On the heat map page what comes up is Force Update. This will also not work...in addition the DUMAOS has also stop working in the QoS traffic priority with no packets being registered.  I even did a factory reset and the heatmap will still not come up.
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: PING HeatMap Will Not Load
It's something we're looking into currently, it will be an issue with the cloud, nothing you need to do on your end for the moment
Message 2 of 2
Discussion stats
  • 1 reply
  • 522 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
