- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Ping assist doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping assist doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nevermind did not fix it. I turned on spectator and it shows without a circle even tho it's in the allowed list. I even tried rebooting the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears my geofilter was bugging out. I just flashed Initial stock, erased all settings, and let the router update back to .40. I initially noticed it bugging out when I left it to ping a dedicated server and the domain name kept changing to new peers showing up on the map, even tho it was still pinging the server.
Thus far geofilter has been nothing but a buggy mess for me. Hope it gets better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After using the feature for a little while it just quits working all together. Radius does work fine but I get people with rather high pings around me as my areas is surrounded with rural parts and poor ISP. Wifi players are also prevalent to many games I play creating high pings. It worked for a few hours and now today it just does not work at all, and to get it working I had to downgrade and upgrade my firmware. Pings of 120ms in South America pop up on my screen and are given the okay to connect. I set my assist to 40ms and it doesn't even care. I don't think this needs an upper limit setting I think the whole damn option is broken and needs to be rebuilt. There is no way some of these peers started below 40ms when they are this far away.
I'm sure this won't get fixed anyway. I've seen a bunch of threads now about different things giving "suggestions" to devs and yet we have not seen a fw update since last year.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you try downgrading to this version: https://kb.netgear.com/000053241/XR500-Firmware-Version-2-0-0-28
Then upgrading to this version: https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
And see if that fixes the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an XR450 not 500. This forum does not allow XR450 to be entered in the model field. I mentioned it in my first post. I've already however done this. I downgraded to "initial release" and went back. I have talked to people on the Duma forum and it has been confirmed the issue lies with Street Fighter V servers and how it detects the peers that it sends to me. The assist is working with Tekken 7 mostly fine besides sometimes letting a higher ping connect still.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The XR500 and XR450 are essentially the same, but you're right I should have sent you links to the XR450's firmware page, oops.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I understand they are the same besides a slightly less powerful 2.4ghz band. Everything else is identical. However I believe putting XR500 firmware might not work or cause a brick. I could be wrong but that be my experience with past routers with identical hardware but different names.
But yes, I believe they came to the concolusion on the NetDuma forum it's related to SFV. You can see the thread here.
https://forum.netduma.com/topic/29120-ping-assist-problems/
In fact you participated in it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
