- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Fowarding for XBox 1 X (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Fowarding for XBox 1 X (XR500)
I think theres some walk through vids. on youtube.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port Forward is not needed if you have uPnP enabled. If your getting OPEN NAT, then your ok.
Also What is the Mfr and model# of the ISP modem the NG router is connected too? If this has a built in router this can cause connection problems.
@gwager08 wrote:
Is port forwarding recommended? I am seeing conflicting information. The NAT on my Xbox is already open, so do I also have to manually open the ports in the router as well? Just confused as to what the best setting is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Manufacturer: Spectrum
Model: E31U2V1
The modem is just a modem and not a modem/route combo. I am trying to get the optimal performace with my setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All you need is uPnP enabled. No Port Fowarding is needed.
Review this:
http://support.netduma.com/support/solutions/folders/16000090646
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, again, if you only have one xbox connected. then you only need uPnP. uPnP is like automatic Port Fowarding. So when it's enabled, Manual PF is not needed.
Performance is debatible and depends on many othger factors. ISP service quality, modem quality, router configuration. Wired vs wireess connections and Game services and bandwidth.
@gwager08 wrote:
Thank you very much. I could not find an answer on this. My buddy has unpn and ports open and swears he is seeing improved performance but I suspect it is a placebo.
