× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
petterpan
Having problem connecting my Oneplus 8 Pro to the wifi after updating the xr700 to firmware version 1.0.1.38
Its trying to obtain ip adress but is failing.
Only way to connect is to manually input dns server.
Tried downgrading the xr700 firmware and then it is working again.
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 11
petterpan
Re: Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
Also my xiamoi security cam is not able to connect to wifi anymore
Message 2 of 11
Netduma-Liam
NetDuma Partner
Did you perform a factory reset after the upgrade? This is often required as it clears anything low-level left after the old version
Message 3 of 11
petterpan
Yes, I did a factory reset, also I found out that the issue is not reletadet to only wifi becouse my wired lg smart tv is having the same problem.
I get the error message "DNS not found"
But when i downgrade firmware its working.
So in short   Oneplus 8 pro = not working (can maually input dns server and then its working)
                    xiamoi security cam = not working
                    Lg smart tv(wired) = not working
                    Win 10 computer = working
                    Arlo = working
Have tried factory reset, hard reset, restart of both fiber media converter and xr700 router.
Message 4 of 11
Netduma-Fraser
NetDuma Partner
Are you using Smart Connect for WiFi? Some devices have trouble connecting with that method. Have you set custom DNS?
Message 5 of 11
petterpan
Seems like somehow the problem have fixed itself😀
Message 6 of 11
Netduma-Fraser
NetDuma Partner
That's great to hear, thanks for the update!
Message 7 of 11
TeddyBearIllu
Netgear Nighthawk XR700 Gaming Router AD7200 Performance WiFi (-100EUS). Firmware V1.01.38.
My new router is continuously dropping my connection via WiFi and LAN.
Please, provide immediate help and support to solve this problem.
Tested and Verified with other router without any problems. Paid 500€ one would expect to get a high quality product that will work in reliable manner. How to trust to company asks high prices you would expect at least the basic functional requirements are met. Maybe customer satisfaction has got a new meaning..
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 8 of 11
Netduma-Liam
NetDuma Partner
Sorry to hear that!
Are you able to access the interface when the connection drops?
Does the connection come back up eventually itself, or do you need to reboot the router to restore connectivity?
What is the exactly make and model of your modem?
Message 9 of 11
TeddyBearIllu
hi,
the connection comes back up eventually itself. No need to reboot the router. Please, see enclosed photo for model (Netgear XR700-100EUS). During my important online customer meetings, the connection is continuously dropping off. Hopefully you are able to give help and support with my problem?!
Message 10 of 11
Netduma-Fraser
NetDuma Partner
Liam was asking what the model is of the modem/router the XR700 is connected to. Give your devices (start with the most important) reserved IP address in LAN Settings and see if they sustain a connection
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1664 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
