- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Qos not working still have bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using to play call of duty but the connection is really bad.
In public the matches its fine but i play privete matches, competitive mode in cod and it seems a diferent game,same ping, but the movment is slower, seems like i have delay to shot, to aim
Bad hit dettetcion
Need help
I already changed the qos percentage but nothing happened
Disable traffic priorization and still the same
Run a test o wave bufferoat.com (i think that is the site) and i got an A "YOUR CONNECTION HAS A SLIGHTLY UNDER LOAD"
PLEASE
DOES ANYBODY SUFFERING WITH THAT?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Qos not working, still have buffer bloat
Using tô play call of duty but the connection is really bad
In public the matches its fine but i play privete matches, competitive mode in cod and seems a diferente game,same ping, but thd movment is slower, seems like i have delay to shot, to aim
Bad hit dettetcion
Need help
PLEASE,DOES ANYBODY SUFFERING WITH THAT?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Qos not working, still have buffer bloat
@Cindas wrote:
I have the xr1000 router, dhcp connection
Bad hit dettetcion
Need help
You would get more and better answers if you posted your question in the section Netgear has dedicated to Nighthawk Pro Gaming Routers.
Dynamic QoS is of dubious value when using a modern broadband internet connection. You will get better performance out of your Netgear router if you disable Dynamic QoS, traffic meter, and access control in your configuration. Each of these "features" disable hardware that supports performance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Qos not working still have bufferbloat
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you wired or wireless connected to the router? Wired is preferred.
Be sure to close all background apps before running any bufferbloat testing.
Try a different PC to compare results.
How is QoS configured on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes fraser, just trying to get help from everywhere i can
- Mark as New
- Bookmark
- Subscribe
- Permalink
hey furry
1)firmware:1.0.0.64
2) I AM FROM BRAZIL, use dhcp connection, dmz desable, upnp desable
3) i am using a good quality lan cable between modem and router, actually i am using the cable thas comes with the produtct (xr1000)
4) Using wired connection
5) all backgrounds are closed when i am running the test or playing
6) qos i set 30% ,10%,70%
auto set up
used geo filter , denyied some servers (peer servers)
but unfornately, unplayable private matches
no matter who creates the host or how many people are in the looby once i start playing the delay comes
- Mark as New
- Bookmark
- Subscribe
- Permalink
