- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Question about Nighthawk gaming router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey guys, I have a question and wasn’t sure who to ask.
Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, the connection is supposed to be good but I experience lag quite often when gaming. I was considering buying the Nighthawk pro for gaming to help combat this. What I was wondering was
-is this a good method to help with lag -I’m only one floor down directly beneath the router/modem, would the distance be a problem since I can’t hardwire
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Question about Nighthawk gaming router
A good place for questions about gaming routers would be here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wireless is not a great option though gaming router may not help if your wireless.
I'd first check the configuration of the wireless. Possible a better wireless signal maybe needed.
Might check into some power line devices for wired connection since ethernet is best and recommended for gaming.
Can try a gaming router and see if it might help some.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
There is also the option of using powerline adapters as well as mentioned above but they aren't as stable as a direct ethernet connection.
Always worth considering.
More details here:
Can be more reliable and faster than wifi, depending in the quality of your mains circuit.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
