Reply
Question regarding XR700
Bansisingh
Tutor
Does it support OpenVPN Client? For example if I were to manually configure it with my own VPN Server, instead of using HMA.
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 3
Guru
Re: Question regarding XR700
https://kb.netgear.com/000053084/How-do-I-set-up-VPN-server-for-remote-access-on-my-Nighthawk-Pro-Ga...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 3
Netduma_Jack
NetDuma Partner
You're referring to a VPN client rather than a server right? If so, you can use our Hybrid VPN solution for this. You should be able to apply your provider's OpenVN config file in the advanced section.
This guide explains how - it's written for our Netduma R1 but the settings should all be the same: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-...
Message 3 of 3
Discussion stats
  • 2 replies
  • 1099 views
  • 0 kudos
  • 3 in conversation
Announcements
