- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Questions before buying XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Questions before buying XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not sure if I can trust powerline adapters 🙂
I am thinking about Netgear GS305 or GS105 or similar devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I personally use a powerline adapter to connect to a router upstairs - it's honestly been really good so far! Still, entirely your choice. Let us know what you decide to get, and if you have any issues please do let us know 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I bought Ubiquiti ER-X and now waiting for delivery 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Did you buy the Xr500 aswell? If so then you do realise that the edgerouter X is a router? It can be used as a switch if necessary (but that is software driven and not a true switch). NETGEAR ProSAFE GS105 Switch may have been a better option!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yep, XR500 is sitting in my home at the moment. I was trying to get Netgear GS105/GS305 but on Amazon.de and local resellers in Poland don't have latest versions of them, and I didn't want to pay for older versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ok, no worries.
The edgerouter X is a good router, I have 1 in my drawer. So long as you are network savvy enough to configure it as you will have to set it as a switch in the edgerouter interface (which can be complicated for inexperienced users) then it will do the job, but it will take it's toll on resources as a switch as it is software driven (it will tell you that in the interface when you configure it as a switch).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Also, if you are unfamiliar with edgerouter and ubiquiti then heres a youtuber who does tutorials etc etc https://www.youtube.com/user/williehowe/videos
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So my latest configuration will be like below;
ISP > EdgeRouterX > configure two VLAN > first VLAN for XR500 and all computers / second VLAN for living room connection if guests need cable connection or TV services
I will set EdgeRouterX as main DHCP server and configure XR500 as secondary.
To test speeds I will also connect my external 8 TB WD Book Duo and test it via WiFi and ethernet connections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I really wish that I had went with another option and had waited before I bought the XR500. Hope it works out for you....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My current connection is 300mbit and this is my current speed. I am using EdgeRouter X and XR500. I set two VLANs in EdgeRouter, one for XR500 and one for living room guests. Firewall enabled with default rules. DHCP is running on EdgeRouter and secondary DHCP is running on XR500. Both are running with latest firmwares.
So far it is very good. In my previous home my ping was always above 10ms in speedtest tests with cable modem and here I have 1 ms.
For some reason uploading picture doesn't work here. I attached screenshot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It is connected to XR500. My config is now ISP > EdgeRouter > XR500. I had much lower results with wifi last night but today I will bring my main desktop PC. It has better wifi capabilities (I have Asus Strix X99 mobo), after that I can show you wifi test results from all of my devices for better comparison.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Here are results of my tests. One with ethernet connection, one with desktop WiFi and one with iPhone 7 Plus with latest IOS version
IOS
http://www.speedtest.net/result/i/2556458669
Cable
http://www.speedtest.net/result/7160614848
Wifi
http://www.speedtest.net/result/7160618100
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I attached it as a file. Forum is not accepting image file uploads for some reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For the moment I have 300mbit symmetrical connection. So, connection with PC is very good 🙂
but iPhone wifi is slow. Dunno why. Also DumaOS Dashboard is not working with Chrome but it works with Microsoft Edge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not seen that error before, if you factory reset does it work as expected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nope, I have only one SSID.
I didn't reset my XR500, I used Edge and Chrome today in Windows and before that I accessed it via Firefox in Linux.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I just did it and nope it didn't solve. I also found that auto firmware check is not working properly. I had 2.1.0.4 and it didn't find anything new but there is 2.1.0.6. I also upgraded to that firmware version.
As for iPhone issue, I separated wifi networks into two, and with 5G it works perfectly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That's not an issue, it's likely they haven't put .6 on the server
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I unpinned everything now dashboard comes empty. When I switch to other tabs I get errors too.
I will just use Firefox, much more compatible it seems. Also Chrome doesn't support HTTPS I think. I get a warning when I tried to connect with https
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes that's right due to a bug in the Chrome web browser itself
User | Count |
11 | |
5 | |
4 | |
3 | |
2 |
