Tokozaan's avatar
Tokozaan
Follower
Aug 07, 2019
R6260 - Port Fordwarding - With PFSENSE
Hi Guys
How does one setup the R6260 as a bridge to ensure that it doesn't assign IP's
The only thing I'm seeing is the VLAN / Bridge settings. Do I need to plug in the internet cable into 1 of the 4 ports or can I use the WLAN port for this, note internet works fine. The only thing is that this possible impacts port forwarding so wanting to set this up correctly
Kind Regards,
1 Reply
  • FURRYe38's avatar
    Please post about this here for your model router:
    https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
    Good Luck.
    Tokozaan wrote:
    Hi Guys
    Kind Regards,
