Broags
Apr 16, 2020Follower
R7000 vs R7000 -100AUS
Hey Guys
Lookimg to find out the difference between R7000 and an R7000-100AUS.
Is it exactly the same just with a suffix for the country of origin (I'm in Australia)
Or are they different?
The intent is to install Express VPN however they say compatible models are R7000p/ R7000.
https://www.expressvpn.com/support/vpn-setup/app-for-routers-netgear/
thanks In advanced
1 Reply
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
