- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 slowed download speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 slowed download speeds
do you get full speeds when you directly connect to the modem? Thats the question. Not your isp.
What device are you testing with?
Are you testing 2.4ghz speeds or 5ghz speeds?
Are you using smart connect?
What firmware is on the router?
many say that factory reset but just click the button. Did you push and hold while the device was powered up? Its usually 7-15 seconds to factory reset it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speeds to YOU get hardwired to the modem?
And the speeds hardwired into the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're directly connected to the modem and only pulling 20mbps over a wired connection when you should be getting 100mbps, somethings not right.
With any troubleshooting, you need to work each step forward.
Start with the modem. Get that to full speeds. Then move on to the router.
What modem is it? (model)
Can you take a screen snip of your modem connections page?
I'd check the ethernet cable too. They've been bad before.
