× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RE- XR500 region lock
bishal
Guide
i bought xr500 through amazon. its in north america and i cant change my  region . i live in hong kong . is it possible to fix the region lock issue?  thank you.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Accepted Solutions
Guru
Re: RE- XR500 region lock
north america has a region lock. but you can try to change it. Read through this thread with attention to telenet and burnsku command.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Region-change/td-p/507639
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
All Replies
Guru
Message 2 of 3
bishal
Guide
@plemans  thank you i fixed it finally. changed my region to china. thank you for your help
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2893 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
