- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Recommend modem to use with XR500? DSL/Centurylink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Recommend modem to use with XR500? DSL/Centurylink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're on DSL a docsis modem won't do you any good as its a cable modem and not dsl.
Centurylink has a list of compatible modems.
https://www.centurylink.com/home/help/internet/modems-and-routers/compatible-modems.html
keep in mind that many of their devices are modem/router combo devices. You'd want to disable the router portion of the modem/router to prevent a double nat.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sadly there's not a lot of support for dsl anymore. Netgear does have the DM200 that has a modem only mode. My parents use it for their dsl. But its a struggle to find anymore. Usually you have to find it 2nd hand. Its not on centurlyink's list but it does work.
Something else to ask centurylink is even just for them to replace their modem. Maybe they'll give you one that can be put in modem only mode or has a DMZ that you can put in for the netgear.
