Discussion stats
  • 3 replies
  • 1080 views
  • 1 kudo
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Tutor
Red led
Hello everyone!!!!!
I live in Brazil and my router arrived, I connected my pc in it, but when connecting a second device, in the case of my receiver, the led of the router turns red, in case the light of the lan that the receiver is connected, is this normal?
Thank you
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 4
Highlighted
NetDuma Partner
Re: Red led
It means you're using an ethernet cable that's limited to 100mbps or the device itself is limited to that speed
Message 2 of 4
Highlighted
Tutor
Re: Red led
Are there any problems with leaving the device connected to the router?
Message 3 of 4
Highlighted
NetDuma Partner
Re: Red led
No problems, as I say just means device won't be able to reach over 100mbps.
Message 4 of 4
