- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router Dropping Internet Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Morning,
I have owned the XR500 for about 8 months. It was running beautifully and now it continuously drops the internet. This happens to everything that is connected via wifi. (I cant connect via ethernet due to where the modem is setup in the house) I am running an ARRIS Surfboard 6183 modem. Both are completely up to date on firmware. Xfinity has tested my modem and reset it multiple times. The XR500 will flash the orange light saying there is no internet while the modem says its fine. Any help would be greatly appreciated. I have redownloaded and installed the firmware manually to no avail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router Dropping Internet Connection
After doing more digging into the forums. I have turned off the smart connect feature and will test it for 24 hours to see if that resolves the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling Beamforming and MIMO and WMM. Set 20/40Mhz Coexistence to 40Mhz only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
it shows it has internet via the lights on the actual router. The WiFi devices pick up the network and are connected but there is no internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
