Orbi WiFi 7 RBE973
Router and switch connections
robturpin
Apprentice
I use a XR1000 router and a GS108v4 unmanaged switch, and I'd like to know if I can (without problems) and should (would get speed/routing benefits) connect them using more than one Cat6 Ethernet cables.
They're currently connected using one single cable between LAN ports, but I've got three ports that could be used.
It seems like using more then one cable might cause loops or flooding, etc. which would be bad.
Message 1 of 3
Accepted Solutions
robturpin
Apprentice
Re: Router and switch connections
I've read about a "packet storm" which is caused by a loop which is exactly what I believe would happen if I connect a router and a unmanaged (dumb) switch together using more than one cable.
Message 2 of 3
All Replies
robturpin
Apprentice
Message 2 of 3
Netduma-Fraser
NetDuma Partner
Yeah definitely no point in connecting them via multiple cables
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 859 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
